Used John Deere 160lc leaking bug time
JPD_
Quebec
Hello there !
I'm new to the forum and a new owner of a used JD 160 excavator. Before I call the company that sold it to me I'd like your opinion on something. I can do "maintenance" but I'm not a mechanic and my first problem is that I don't even know the name of the part that is leaking. but It dripple bit time, it's dark black so I suspect motor oil.
Can you guys help me on this ? What's leaking ? any gasket or something I can change or that's a bigger problem ?
Check the video to see it leak clearly.
Thanks a lot
mekanik
Canada's Northwest
Looks like a rear crankshaft seal or maybe the flywheel housing to engine block bolts.
The pump will have to come out and the flywheel to see better.
Mike85
Ontario
There’s a ton of smoke in the video does the muffler have a leak? It looks like a rear main seal. Not too big a deal to replace. Pumps and flywheel have to come off. If exhaust is leaking it’ll take out the new one
JPD_
Quebec
@Mike85 "There’s a ton of smoke in the video does the muffler have a leak"
Indeed there is a bunch of smoke, that's actually why I first stop and went looking at first . I'll have to check for that leak too, thanks for pointing it out.
All right for what I can google out of your replies rear main seal and crankshaft seal are the same thing right ? And it doesn't look to be expensive.
I purchase the repair manual online I'll have a look.
@mekanik you mention it could be the " flywheel housing to engine block bolts" I'll try to take better / closer picture before removing the Pumps and flywheel
Thanks for the quick replies guys.
