I started having intermittent issues with my rear down function outrigger, that eventually got worse and worse. So, not knowing any better and being in a hurry, I took the 30 ton National to my local CAT shop. They are of course the most expensive route, but they are 1 mile away from my yard, and I know the service manager and he gets me in and out ASAP, meaning the work I don't miss makes up for their premium expense.
So, they quickly determined the cause was the valve for that function, and the next day the new complete part came up from SLC and I was good to go before noon, and made my already scheduled job at 1. A couple weeks go by, and the same thing happens again, but this time I have a spare valve (cartridge?not sure of the the terminology) and as I had streamlined the process of removing the rear cover (putting disconnects on the wires going to the lights, backup beeper, etc., so now I can set it out of the way rather than work constricted by it) and in 5 minutes the 2 week old one was out and another new one in place and again I was able to meet my work schedule. But now I see the removed valve is missing a teflon ring on the bottom of the O ring and the teflon ring on top is half broken.
So, FINALLY wising up, I get the parts book out and order just some rebuild kits, not the whole valve, which I assume are the two teflon rings and the special O ring. I say special because of it's cost, who knows? But the issue of it eating these rings is what concerns me, and I don't like the idea of them floating around in the hydraulic system either. At least now I know I can fix it quickly onsite and not be stranded somewhere with a down outrigger, but something ain't right.
