Variable pressure compensated valve on hitachi ex220lc-3
natetate100
Arkansas
Hey guys, so I've been having trouble getting my arm cylinder to move right. It moves extremely slow. So I was going through the stuff trouble shooting and went to check the pressure going from the solenoid valve to the vpcv and the pressure stays from 600 to 900 psi depending on the rpm it doesn't change when you move the lever. I cleaned it nothing changed. I also checked the voltage to it, reads 27 volts just like the boom. Also when it was unhooked the arm moves completely fine. So 4 questions, first what would be causing that? Is the pressure supposed to change when you move the spool. Last is does it have to be hooked up? Can I run it without that pressure going to the vpcv? I appreciate all of your help.
