Pretty neat stuff.
I've never seen these before,so pardon my ignorance,but what are they used for ? Are these accurate enough that they can tell the operator exactly where to dig ?
How well do they hold up in such a harsh environment ?
They work very well. The horizontal error on the newer systems, such as the one Chris is showing) are within +/- 1" I believe. The vertical error is even smaller, depending on your satellite strength anyhow. The monitor includes a chip with is loaded with a CAD map of the the specific job, with the finish grades programmed in. If the system is accurate enough to do pipe work, maybe to keep the run on target and manholes in they're proper location, but I do not think it is accurate enopugh to give invert of pipe to the tight tolerances that are sometimes required. Weather is not an issue, and it does not affect the GPS whatsoever. That being said if you get too close to a wall, or under trees you can lose your signal, go figure
The company I work for has GPS on 90% of our dozers, at least 2 815F compactors, and a growing number of our mass excavators (as I pictured above).
I hope that all helps, if you have any more questions feel free to ask, I'll do my best to answer them.
Is that Top Con stuff?? Maybe from Caron East?
most trimble systems require a base staion set up on the job. i beleive all the systems require dual masts. everything from baldes to hoes, graders and scrapers, you can put them on. im not sure about an held hand unit though if that needs a substation though.
The contractor I'm currently employed by is very seriously looking at getting into GPS for the coming construction season. The salesman from Trimble has been really pushing his product on the head honchos and he did a pretty good job because I think they're about to dump a couple hundred thousand bucks into GPS equipment this year.
Would you guys say that Trimble offers the best product?
Is it true you need a total station to take a few shots first before setting up the job for GPS?
I think my employer is most interested in getting GPS for a 140H grader and D6R at first and then probably install it on a 345BL pipe hoe or two next year. They might just go ahead and get some new iron that's more designed to be incorporated with accugrade like a D6T, 140M or 345CL instead of adapting the old equipment. I wouldn't put it past them for a second, the D6R and 345BL are getting a little worn.
