Mark250
- Joined
- Aug 30, 2015
- Messages
- 1,243
- Location
- victoria,Australia
- Occupation
- heavy equipment technician
Hi All hoping some one can help with frame hitch specifications for a Volvo A40E ATD
while rebuilding the hitch on this machine I have fitted the two sleeve bearings to the frame link part numbers 150 22441(closet to front of machine and ) and part number 150 32646
Also I have fitted the two large bronze type bearings to the rear frame part number 15117704 (front) and 15117996 (rear)
my problem is that I can not slide the frame link into the rear frame ,there appears to be a problem with the bearing and bush dimension's
I want to measure the OD of the sleeve bearings and the ID if the large bushes to see which is at fault ,how ever I can not find these dimensions in pro sis if they exist
if a member has access to this information it would be much appreciated
Mark
Mark
