Hi,
Serial - VCEC210CL0012080X
We got this machine few weeks back
- every time to start first time in morning we had to use the hand primer on fuel filter
it would stay going for an hour maybe or longer than would die out again as if air is slowly getting into system
comes up clogged fuel filter on dash
I’ve done the following in order with first to last
changed fuel filter and inspection bowel
Didnt help so I had ordered the filter type without the clear inspection bowel at bottom and that also did not work
I will change hoses from tank to filter and filter housing to high pressure pump
I’ve searched the threads and I’ve seen some guys have high pressure fuel pump issues and the relief valve on rail
? I hope the hose changing will
Solve but I’m not sure it will.
Thanks guys - I’ve inculded pics of serial plate
