farmmaterialmover
My volvo ec 210cl will not throttle up in manual mode. If you quickly switch it to auto mode and turn idle up over 1700 rpms it will usually idle almost indefinitely. But if you put it under load it will give you the red engine malfunction shut down screen and derate rpms.
If you don't start the machine and simply turn the key on without switching to auto throttle, it will quickly give a yellow no communication screen which if you click on it shows psid201-09 source e-ecu. If you have the switch in auto and key on, it usually won't throw a warning screen.
It always starts in manual position. Sometimes it will start in auto position, but not always.
If you run machine at low idle, it doesn't matter what position any switches are in, it throws up a no communication warning soon followed by a engine shutdown warning. Once in awhile it won't give the yellow warning, just go straight to red warning.
Where do I start?
Where do I start?
