So I have a foot pedal that works a hyd element (spool valve) and has 2 small lines going to the end of the boom. I also have a larger pipe on the side of the boom going down that returned to the tank so thats three lines on the boom.When I work The foot valve in hyd fluid comes out of one the small line at the end of the boom. When I work the foot valve the other way hydraulic fluid just drips out no pressure. On the auxiliary spool valve there’s no pressure compensator on the spool valve I have to order them but I need to know what else to order because it doesn’t work and think I’m missing something may be a T in the line or something. From the right going left it’s the fifth hyd line that’s the spool valve that works the Aux foot Pedal.
I followed the lines from the valve and they go straight to the boom. I haven’t hooked Lines to the hydraulic cylinder for the Thumb but I would assume when I work the foot pedal in either direction fluid will flow out of one line and then out the other line.I get pressure only out of one now. Does anyone know what parts I need to make this a Bi Directional valves and a diagram. My serial # 28121609
Thanks![8ED66C91-A64F-4AC2-90B3-10A12654B453.jpeg 8ED66C91-A64F-4AC2-90B3-10A12654B453.jpeg](https://www.heavyequipmentforums.com/data/attachments/220/220484-efe7428ffbc263892160a36efac6280f.jpg)
![46FD1F72-DB94-49F0-8DC4-E685598A7BD6.png 46FD1F72-DB94-49F0-8DC4-E685598A7BD6.png](https://www.heavyequipmentforums.com/data/attachments/220/220486-c7196a2564b27d790e2c742a6feff591.jpg)
Thanks
