Volvo ew180b error codes
ROAMER_AUS
Croatia
Hi all,
I have EW180B bogging down, engine RPM drop and sometimes shuts down when loaded.
Error codes that it comes up with:
130 SID 254 13
130 PPID 1193 12
I can't find anything on these error codes.
Any help would be greatly aprecciated!
Also I am looking to purchase a service manual for this machine if anyone can point me in the right direction.
Thanks!!!
ROAMER_AUS
Croatia
Thanks for the info uffex!!! I managed to get codes decoded elswhere also. Now must be broken wire somewhere. Does anybody have a diagram where is this solenoid connected to? I mean what pins of the computer. It is impossible for me to trace it due to layout of the excavator. Also, resistance value of the solenoid?
Thanks!!!
uffex
Lincoln UK
Admin
Good day
Here is some information may be of help.
Kind regards
Uffex
  • PWM9101.pdf
uffex
Lincoln UK
Admin
Good day
We are talking transmission error, see attached
Kind regards
Uffex
Kemper
Ontario
Would this be the right area? And would the solenoid to the far left be the one in question
Pictures to go with this
uffex
Lincoln UK
Admin
Good day Kemper
MA4202 is the high low speed solenoid see attached, there are a number of diodes need checking out.
Kind regards
Uffex
  • MobileTrannyWire.pdf
Kemper
Ontario
Good day Kemper
Kind regards
Uffex
So I have voltage to sensor 3 but when I check resistance on sensor I get o/l which I take as bad ?
Kemper
Ontario
So found the sensor for m2404 open, where others were around 26-30 ohms, I swapped sensors and problem followed to another.
uffex
Lincoln UK
Admin
Good day Kemper
Am I interpreting your post correctly that you have located the issue to the solenoid coil ?
Kind regards
Uffex
uffex
Lincoln UK
Admin
Good day Kemper
See attached
Kind regards
Uffex
  • 130-PPID1092.pdf
RainerJR
Estonia
Hi, can you tell me witch solenoid controls the oil flow to the parking brake system?
MA5501 as i can see from the wiring diagram...
Rainer
uffex
Lincoln UK
Admin
Good day
See attached.
Kind regards
Uffex
  • EW180B Solenoids.pdf
