i have a 320 komatsu payloader that when it gets warm it takes a few extra seconds to shift when going from forward to reverse any boby know this problem, Hoping not going to be major i believe this machine shift electronicly Thanks KMS
I haven't worked on many komatsus and I'm not sure the 320 will be equipped with cushing valves or not. But if it is this would be a good place to start looking. Of coarse you've most likely allready changed fluid and filters and cleaned the pickup screen.
As I said I don't work on many komatsus but if they are like many other brands look on the side or front of the trans. There should be a small block with detent style plugs in it. These valves are usually just a spring and ball type deal springs break or get weak, trash gets in and binds the ball or they just plain wear out.
Thank You You Have been a great Help , Sorry if I seem demanding I'm not Trying To Be KMS
