Weak tilt
Driver2022
Ireland
It's a komatsu Wa100. Year is 1994 i think. It's very weak in the tilt position. Was pushing up silage and was getting caught trying to flick the silage. Will lift up and down no problem but it's weak on the tilting.
Zero leaks anywhere in the hydraulics. Is this due to a weak hydraulic pump or or something to do with the ram?
Vetech63
Oklahoma
It could be several things. Have you noticed any cylinder drift on the bucket cylinder? If your boom lift is good then its not going to be a bad pump.
Driver2022
Ireland
No I havnt really noticed any drift but want looking out for it either if you know what I mean.
Could there be something in trouble internally in the ram
Get everything in the implement system up to normal operating temperature. Cylinders should be warm to the touch. Set the lift so that the bucket is a few inches off the ground and the tilt is about half way down its stroke. You may need a set of steps or a ladder.
Measure along the tilt cylinder rod 1" from the wiper seal and using a black marker put a mark on the chrome. Wait 5 minutes and measure again. The difference between the two marks is the cylinder drift. Report your findings.
Driver2022
Ireland
Wait 5 mins without putting load on it is it?
Driver2022
Ireland
Would it be possible to disconnect the pipes off this ram and put a guage on the pipes to test what pressure coming to the ram? Like you can do to test the back of a tractor
Yes. Sorry I should have been more clear. Get the front end into the appropriate position as described earlier, move all the implement controls to the HOLD position, put the implement lockout switch (if it has one) to the LOCKED position, shut off the engine, and mark the chrome of the tilt cylinder rod. Leave it for 5 minutes then go back and re-measure.
Tenwheeler
Georgia
Not so scientific but start if up cold at idle. Hold the tilt one way for two minutes and then the other. May need to repeat. If one cylinder is cold and the other is warm the warm cylinder is bypassing fluid.
