wear spec. for CAT 289/299 ROLLAR/ SPROKETS
joedirtyshirt
PA BERKS CO.
The instructions are also suitable for this machine.
THANKS MUCH, New question for you since you seem to have access to info my Dealer can't find or get, in the wear guide (dealer never heard of) it mentions Kit for rear frame & front frame gap would you have any idea's on Cat kit , as of this morning Cat system is down for a week, according to my dealer, and the shim kit for the torsion axle end play, this is my oldest machine and tracks are starting to rub boom GTC01613 2013 299D
All your dealer has to do is put a question into the Cat DSN system mentioning the document reference (M0073906) and quoting the text on Page 12 where it mentions..... "Shim strips are available as a permanent, welded solution to maintain a proper clearance between the two frames. Consult your dealer for this kitted solution".
Also attached is the M0089413 document regarding shim wahser sizes and Part Numbers. As mentioned in M0073906 look specifically at Table 6.
  • M0089413-06.pdf
