welding cat 426 backhoe boom
gusbratz
PA
spent the day arcing off those patches, they were harder than i expected. looks like they were odd shaped pieces and they just filled in all the openings with weld. so there was no telling what kept them holding on for dear life. i had to arc them into squars then melt them off with my torch. I also got the cracks v'ed out and ready to weld. then i have to figure out where the cheapest place to get cyl rebuild kits is. i need to rebuild all the hydraulid cyls.
gusbratz
PA
had the day off and have been makeing some progress. the more i work and look at it the more cracks i find and grind out. the project is growing:D
Mike.580ck
Kansas
looks pretty good Gusbratz, i am liking the plates to strengthen it , i also am looking to rebuild all the cylinders on my machine and i have been looking i found on Ebay a whole machine cylinder re pack kit for under 300 dollars so that might be the way to go
bowen
N. GA USA
Electrical Panel Builder
I have ordered all my seal kits from Coleman Equipment
http://www.colemanequip.com/
There are several others like Broken Tractor or Eldridge that sell Case parts online.
Coleman seems to have most in stock and cheaper than any local dealer.
They will be genuine Case OEM kits.
On mine all the cylinder part numbers are stamped on the ends on the cylinder. You need this number to select the kits
gusbratz
PA
Finished welding it up yesterday. I welded the round pieces I cut out of the reinforcement plates for the pin bosses over the cracks on the bottom. Did one pass of 1/8” 7018 then one cover pass of 3/16” 7018 on most parts. Hopefully it all holds up. May start rebuilding cyl's tomorrow.
gusbratz
PA
I finished up welding the boom and got it installed. repacked the boom, swing stabilizer and dipper cyl and have moved on to looking at the stick. I pulled the collar and removed the stick to find more cracks in the end of the dipper. Look at the weld on the inside corner. I don’t understand why anyone would even attempt to repair cracks on a backhoe if that is as good as their welding skills were.
gusbratz
PA
some reinforcment that was welded onto the coller to try to stiffen things up i guess.
Kudos for the job you're doing. It must be a bit daunting removing all those patches never quite sure what you're going to find underneath them. Liking the look of the repairs you've done so far and it was really good to see the pre-heat on the areas you were planning to weld.
