HATCHEQUIP
Seenum alot over seas in the citys where their wasnt that much room but the mini ex took alot of that market now
Nope! I'll pass on those plans. Big barn (by Vermont standards) collapsed a short time back. I theorized they were engineered exactly enough. Farmer runs into a brace, damages a few pieces, then a leak develops in the roof. An uninformed carpenter cuts in a door where no door was in the plan. There was a stiff wind, not unexpected, it collapsed. It isn't clear how many cows died. In the aftermath, numbers get vague, 30 died, 60 died, none died, hard to tell.Google up the USDA plans, thousand of plans for hog sheds, barns, anything you'd want to build.
Those huge barns with the curved roof, you need the truss plan? https://web.utk.edu/~ggrandle/Programs/Plans/6411.pdf
https://web.utk.edu/~ggrandle/Programs/PlanList97.htm State Land Universities have them, lots of them.
Joe H
As I say, I haven't seen one. The upright stabilizers I haven't actually seen here either.Deere 315 & Cat 428 here in the states
315 series is unusual also, plenty of 310, A,B,C,D,...........The 315 isn't one I'm familiar with. The 300, 400, 500 were common also.Dad had 315A around 76' it had early outriggers deployed from the bottom if needed pull the pin slide out 2' like a regular hoe foot printView attachment 358362
Man @AU.CASE that's some nice looking dirt and beautiful landscape!
Side shift is a feature seldom seen in USA. I can't think of an example I have seen, only photos. I think I'd really like one if only to shorten the tractor, avoid the big tail swing when turning, and beter balance the tractor climbing steep hills.
Perfect reason to look for a used hose crimper. I was sick of paying 500% markup for hoses and now make a bit of money on the side.Replacing hoses is a way of life on the farm. I replaced (2) 1" drive hoses on a skid steer a couple weeks ago to the tune of $300/each. Today, I found one of those new hoses has a slow seep in the fitting. Down time to tear it out, see about a warranty replacement, then back together. About an hour after I got the skid steer done, I find a steering hose on one of our big tractors is in rough shape and we're about to start long days of tillage with this tractor. Back to the dealer I sit, waiting on another hose to be made.
I would have to stock so many fittings it wouldn't be worth it.Perfect reason to look for a used hose crimper. I was sick of paying 500% markup for hoses and now make a bit of money on the side.
That 1” line was probably 25 bucks to make.
