Short Radius
You will ALWAYS find SR's will weigh more than conventional machines. To discuss SR's we CANNOT use the original weight classes as an indicator or of performance. They WILL be heavier than the original machine. If properly designed for North American markets. (No, I do not work for Kobelco or a dealer.) Example, Kobelco SK 210LC counterweight, 9800 pounds, Kobelco 235 SR Ctwt Japan..14,000#, North American 16,000#.
To carry such weight and still have durability and travel power to give ability to turn, the undercarriage is from the next size larger machine (At least on Kobelco who really started the SR movement)...SK 250LC as is the swing bearing.
Swing power MUST be increased, verses a conventional machine, as on an incline, the counterweight cannot help the boom swing up hill as does a conventional machine.
The booms will be different due to needing to raise it higher than a standard machine. Hopefully, the sticks will interchange with your other machines. They do on Kobelco. Most drive and hydraulic components will be the same or very similar as standard machines
Stability is actually BETTER on the 235SRLC than the SK 210LC due to it's undercarriage and weight.
You will note that SR's by any manufacturer, feel..."Nervous". Consider a tipping condition due to large bucket on a conventional machine with the counterweight around 9 feet from the center of rotation, now although heavier, move the counterweight to 4 feet from center of rotation. During tipping, the conventional counterweight will move up and down, perhaps 4 feet, while the SR will move 12" at the similar tip condition due to it being closer to the tipping point and center of rotation. Stability is similar, but the actual tipping event is much faster on the SR.
Cabs must be smaller to keep front swing radius as low as possible.
While paint and sheet metal damage is important, consider safety of passing soccer Mom's and workers on the job.
My two cents.
