DirtyHoe
Not sure if the following is an original idea or not. I have snapped three tiny o-rings(.101 ID X .07 thick) trying to install them on the guide that is inside the secondary relief valve to the loader control valve on my 580C. I put the guide and the o-ring in hot oil on the kitchen stove. By the time you get them out of the oil and try to install the o-ring it has cooled down and won't stretch. Then snap! I ruined another one.
So here is my trick that worked the first time. After heating the oil in a pan to about 170 degrees I put the o-ring and guide in the oil to soak up the heat for a minute. Then I put the parts and hot oil into the bag and sealed it shut. Next I installed the o-ring by working through the outside of the clear bag. It worked perfect the first time. Doing it this way gives you a lot of time to install the o-ring without the oil and parts cooling down.
Steve
Steve
