crane operator
A knuckle with a 20' bed would do lots of things for you crane op, including some overhead clearance jobs. You could drive by and set that ramp and all sorts of cribbing. No forklift needed.
Make some modular bases, for example. it would be a base unit with a sling built into it and you could stack cribbing on as needed. Swing it into place in one piece.
I've looked at a couple knucklebooms. They want big $$ for the big ones. I don't really want a 100' of reach, but it would be nice to have enough capacity to do jib inserts/ offset. Or for setting mats and such. Mounted up, it pushes a truck into $80,000- 200,000 pretty quick. The one's I've come closest to buying were dismounted, and I'd mount it to a truck.
