‘95 Cat307 graymarket track adjuster
Newguy 747
New York
Hi everyone, left track adjuster keeps getting loose. Does anyone have a procedure or shortcut they could share to efficiently remove the adjuster.?
Do I need to remove track or can the job be accomplished with the track in place?
Newbie here appreciate all the help I been given from this website
Thanks
Mechanic_Caterpillar
Russia
Your Japanese market excavator 9ZL02090 is equivalent to excavator 307_2PM1-256, so the instructions from 2PM apply.
You do not need to remove the track, you need to remove the track roller under the tensioner. See the manual attached.
  • 6I6578 ADJUSTMENT GP-HYDRAULIC TRACK.pdf
  • 307_2PM_Hydraulic Track Adjusters.pdf
  • 307_2PM_Remove & Install Track Rollers.pdf
Newguy 747
New York
OK, great I’ll check it out. Can’t tell you how much I appreciate this information. This website is great!
Tyler d4c
Salix Pa
If its anything like the 307ssr 2 bolts it falls out the bottum. We had to make new barrels for ours as the hole was not straight or round
