just-a-mechanic
Hey Guys I am new here and I own a 2002 Terex Backhoe as the description states.
I have scoured the internet and short of buying parts from Russia, looks like I'm left to my own devices for wear items and common upkeep.
I would by from Russia but cant get any shops to respond to my emails... must think I'm scamming them
This Terex has Carraro axels and a Turner Transmission Shuttle/synchro Shift.
I have a leaking Front left axel oil seal past the reduction gears. So, I need to find these parts. I have to look up the axle model number and ill post it here.
I am looking for the wear pads on the extend-a-hoe internal and external. No luck anywhere, well except Russia. Good luck getting Terex Dealerships to help, including corporate. I am aware of the story on Terex and how things came to be.
I'm thinking about cutting my own using Teflon flat sheet. I have a CNC Mill and can cut the profiles, would be great to get a pattern and thickness to match the new ones. Mine were missing at the end of the dipperstick - I guess the previous owner "forgot" to put them back in. So the Lower section of the dipper does not have any wear pads installed.
Also depending where you look: operator Manual, Maintenance Manual and 760B Maintenance Manual all state to put Different Oils into the reduction gears, front axle and rear axle. 80W API GL4 for the Rear and 80W-90 API GL5 for the Front, Seems That Mobil Fluid 424 Works in everything,(Alternate fluids chart in manual). (I don't think that is the best idea for the reduction gears) I plan to use 80W Gear oil, but I have wet brakes so I need to make sure its compatible.
AW46 For hydraulic fluid.
Anyone Know who makes the hydraulic system? I'm preparing to gather information and repair parts source before I have a problem.
This machine is new to me, and is for Farm use.
I am doing a full service before I start using this machine. It is very confusing because none of the manuals agree with each other, oils and viscosities.
