2012 2954D Log loader surging when walking or heavy load on engine
Hallback
Aberdeen Wa.
Gyppo tower logger
Put injectors, lift pump, FPR valve in 550hrs ago, fuel filters new today,ect.
It will surge when walking it or putting a load on the engine. When the selector is in HP mode it does it when walking but not when it is not in HP mode.
I had Pape out a few weeks ago as it was doing that and we found a pinched fuel line and bad plugged filters so when it started doing it again today I put new filters on but it is still doing it.
Any ideas?
Hallback
Aberdeen Wa.
Gyppo tower logger
Now it wont start this morning. Showing code 157 17.
I have primed it, tried the gas rag over the air filter (which made it run at about 220rpm until gas was gone) and replaced the fuel filters again.
I am at wits end.
Mike L
Texas
Self employed field mechanic
Were the filters still full of fuel? I'm wondering if your sucking air somewhere
Hallback
Aberdeen Wa.
Gyppo tower logger
Yes, still full.
Pulled feel to injection pump from primer pump and it didn't run out as you think it would. More of a trickle.
Primer pump takes a pump or two before it goes soft like it has pressure.
Mike L
Texas
Does that machine have the screen in the tank ? Maybe have a restriction there
Mike L
Texas
I would check that. Had a Jd dozer with similar symptoms. Had a dead bird in the tank and plugged up the screen like this
dixon700
pa
heavy truck mechanic
How in the world did a dead bird get in the fuel tank?
Mike L
Texas
My guess is that somebody left the fuel cap off the tank and he flew in to make a nest. We ended up cutting out the side of the tank to clean it out. Not fun.
Hallback
Aberdeen Wa.
Gyppo tower logger
Not sure, got a call from another side & had to run parts. Will know in the morning.
Hallback
Aberdeen Wa.
Gyppo tower logger
I have deere filters and I suspected air in the system also. What is the best way to bleed it out on these?
Drifter
Check to make sure there is a o-ring between the fuel filter and water separator bowl. Will not leak but runs bad. Pull line from tank to first fuel filter and see if you have fuel running out from the tank.
Hallback
Aberdeen Wa.
Gyppo tower logger
Ok, so I got it to start with the new rail pressure sensor but it lesks badly from there now. I had to get a set of crows foot wrenches overnighted to get it tighter. Will report back this afternoon.
Thank you all for your help and time!
Hallback
Aberdeen Wa.
Gyppo tower logger
I got the sensor sealed and was able to start it with a shot of ether. It smoked for about 5 minutes as I was running it and was down on power. When I shut it off & tried to start it again I got the same no fire/knocking/white smoke that it did when trying to start it friday.
Hallback
Aberdeen Wa.
Gyppo tower logger
So you have a supply side issue.
Some things Ive seen on the d series are loose/pinched hoses at the tank,off brand filters leaking air into the system and clogged breather caps.
You are referencing the breather caps on the filter heads?
