keith@cooglerconstruction
2014 Bomag MPH 600
Serial # 1015900860000014
Having a problem with noise on the left side of the milling drum, hydraulic pressure was correct and left side motor was removed and checked for possible,
bad bearing or motor issue none found motor was taken apart by a hydraulic shop and good as well. Our company was told that there is a transmission assembly in the milling drum which is turned by the
motor. Bomag offers nothing in their manuals for taking apart the transmission assembly in the drum.
Does anyone know about the noise issue what it may be and how to tear down the transmission in the drum. The noise starts after the machine has run for,
about 15 minutes enough time for the hydraulic fluid to heat up when that happens the drum seems to drag down also causing the machine engine to drop power.
