Hey everyone I am looking for advice on wiring a ford/new holland 555e alternator. The OEM setup is for a 3 wire alternator and that is what is currently on it. When I bought the backhoe the alternator was not charging so I was manually charging the battery and not shutting it off when I ran it for the past year. Now its time to give it some love so I began working on my list of issues.
The alternator that came on it was not for a backhoe and had a different mounting bracket that appeared to be off an old chevy pickup. I bought an OEM alternator and fabbed a new mounting bracket so its in and turns well. My issue is with the wiring, the previous owners ran only 2 wires, one to the battery via the starter solenoid power (on the stock wire) and a new line going to the fuse box (I don't know if this was supposed to work like a remote). This didn't work so I looked up the correct wiring in the service manual and installed the original wires coming from the main harness. This also did not work, I was getting .5 volt on both the power and warning lamp wires and nothing on the speed sensor wire. (I don't have a functioning warning light on the dash).
So I am now at the point of having to run new wires for the alternator and I am wondering what the bare minimum is that I have to do to make the alternator function? Any advice on this is greatly appreciated
