silverstr8p
This hoe had been sitting a super long time. I cleaned the rust out of the tanks and bled the lines and it ran great, but was stuck about half throttle. The accelerator pedal doesn't seem to change it. It kept doing this so I pulled the fuel shutoff to kill the motor, but now I can't get it running at all, except on starter fluid.
I tried to bleed the injectors by loosening the two nuts on the high pressure side of the pump near the injector and cranking until a tiny bit of diesel bleeds out, am I doing that right?
