silverstr8p
I'm trying to resurrect a Case 580C which hasn't run in a long time. Got it running, but now starter switch doesn't make starter turn over. It doesn't try to engage the starter solenoid, it's like there's something that's not letting it get the signal to the starter.
I pulled off the shuttle fwd/reverse wire plug and tried to jumper across it and remove the jumper, but neither make a difference.
I've cleaned both ends of the positive and negative wires coming off the battery and made sure the battery's good. There's almost no voltage drop when you push the starter button.
If I jump across the terminals on the starter the engine cranks fine. Should I look at the starter switch itself or something else next?
