700K Crawler Dozer VCU 116.0, VCU 116.4
DipStick69
Fargo North Dakota
Mechanic
I have this 700K crawler dozer throwing code VCU 116.0 for a high brake pressure causing the machine to derate and not rev up so i got the manual and found where the brake pressure sensor was that's detecting it and unplugged it to and run a pressure test on it, and i get 428 psi of pressure which i believe is good, unplugged the code VCU 116.0 had changed to VCU 116.4 that i couldn't find any information on. Anyone know what this means? do i have a bad sensor or something?
mg2361
Pennsylvania
Equipment Mechanic
A .04 FMI is “voltage below normal”. That is why it changed to a 4 when you unplugged it.
mg2361
Pennsylvania
Equipment Mechanic
That depends, did you have any pressure to the park brake when the park brake was applied?
Plus a machine serial number is needed for accurate information gathering.
DipStick69
Fargo North Dakota
Mechanic
| Serial#: 1T0700KXCEE270343 | and i put a gauge to the system and i get 428psi of pressure which i believe to be a healthy brake pressure.
mg2361
Pennsylvania
Equipment Mechanic
If you read brake pressure on the line going to the brakes with the park brake off, then it is not the sensor.
