While mocking up the mounting bolts for the edge I happened; to look straight down the right track and noticed its all straight... except for the front. So I took the cover (what I thought was the cover) off of the recoil spring which then abruptly slid the front idler backwards. I noticed you could rotate the front idler a little bit in each direction... my theory is that the hydraulic tensioner and recoil assembly were crooked from some sort of mishap, and since the idler carriage has no alignment guides in the back, its free to angle the wheel wherever it wants. I did notice that the left track has a new'er' spring assembly... and since half of the bolts are broken off on the right tensioner... it was allowed to pivot and push the wheel out of alignment.
My fix for the track alignment:
With the tensioner assembly taken apart, I pulled the wheel carriage perfectly straight (using calipers), I then welded a piece of 1/2" square bar (about 2" long) right next to the inside of the idler carriage to keep it straight while tensioning.
Conclusion: after measuring, it appears that its a little over corrected by about 1/8, however it drives much straighter.... its not completely fixed. However its not NEARLY as annoying as it was before.
![IMAG1358.jpg IMAG1358.jpg](https://www.heavyequipmentforums.com/data/attachments/147/147146-8e45137fa49dc9f244a7c02828f9a1fe.jpg)
![IMAG1360.jpg IMAG1360.jpg](https://www.heavyequipmentforums.com/data/attachments/147/147147-e3182f18aec2d8ab2d8c213b1a77d85e.jpg)
![IMAG1361.jpg IMAG1361.jpg](https://www.heavyequipmentforums.com/data/attachments/147/147148-0229f5396e6548303b1c26abb8df8046.jpg)
![IMAG1362.jpg IMAG1362.jpg](https://www.heavyequipmentforums.com/data/attachments/147/147149-8bc7648ff413cb05a5be739d4ae143a8.jpg)
![IMAG1363.jpg IMAG1363.jpg](https://www.heavyequipmentforums.com/data/attachments/147/147150-89eabdce724af64329eba2144a5e53ca.jpg)
