Ok-It's had stats, water pump, radiator core cleaned, fan hub rebuilt, belts, shrouds are in-place, nothing
obstructing air flow to radiator. Any extra crud should have been found in core if it came from block.
If it was that far out of tune it should be low on power and high fuel consumption, more than it would
consume normally. If it had psi above normal in the coolant system it should be pushing coolant past cap.
So tear down time.
So tear down time.
