JeremiahSr
I don't think you need to mess with bevel gear an pinion to do the clutches an brake bands. In fact if you haven't set up bearing pre-load and backlash before it's probly best you don't open that can of worms. Take all the bolts out of each side of the clutch flanges. Slide them together off of flanges and pull them straight up. The clutch release yoke just slips out of a cup in the bottom of the case. It is 2 big assemblies each side of bevel gear. You can jack the machine on the track to slowly move it so the clutches slow roll to remove then reinstall bolts. Make sure the yoke goes back in the cup when installing. Also make sure you have the band turned the right way before installing clutch! I have done this and it is a bad day when the band won't pin up and you have to remove all the bolts and pull the clucth...then reinstall again! It is a long process but it gets done every day somewhere! But if all this was working fine and you don't see any obvious problems to address just do the bands. After you clean it all up and reassemble....it will be alot easier to tear down years down the road if something else goes wrong in there. The only good things to do while the clutch is out is to check the brake release yoke bearing and to take a measurement of the discs of the clutch. If it is under measurement then you will want to rebuild the clutches when they are out. This too is a big job. To rebuild these you have to press the flanges on and off with special tooling to get the proper tonage, and to release the keepers in the springs an install takes other special tooling. Alot of mechanic shops has these tools but not many owner operators that i know of do. When you get that far for a measurement let me know an i will look it up for ya. Good luck! Heres a few pics.
