HATCHEQUIP
push the brake hubs toward the center to get paast flanges take locks off bearing blocks and backoff bearing adjusters so there not holding tension when lifting out and you need the extra clearance so you dont chip gear teeth take sperical rod end out and lift with chain or cable in those holes but with the longest legs that you can work with because those pieces set in a ball pivot on the bottem and the more your trying to squeze the top in it makes it harder getting them out and a pain putting every thing back in and to get them back in their holes there are two square plates on top of the filter housing cover that you take off to adjust a and b swivel feet and yes those other pieces will have a little play ive allways set the back lash to speck but check in 4 places and set to speck at tightes point you will set this with the brake hub bolts out so you can turn everything and not have to do it with a bottle jack under the tracks if pinion is sloppy you will have to fix it or its going to start shucking teeth one of these days did you ever check the final drive oil levels to see if they were over full?? are we having fun yet haha take care Randy
