Yes, the crack is where the red circle is at. It is about 2 inches long (the one that is leaking). there is also one about 2 inches away that is parallel to the one that is leaking. It looks as if something square in shape may have hit the case, cracking one area enough to cause a leak and the other side just enough to have a hair-line crack. I have some JB Weld, 2 part epoxy that I was going to try if the housing is too hard to remove. See my earlier top picture, the shaft that you circle in blue on mine appears about 6 inches long. I was wondering if it unbolts somehow from a different shaft that appears your picture as smaller. If so, I was wondering what I would have to do to remove the casing that you made a red circle on. Thanks a bunch for all your help!
