I have a Case 590 Construction King and recently noticed a Vibration/rubbing while I was driving. The Vibration/rubbing will stop when the backhoe is in park but will return if the RPM is increased. It feels/sounds like it is coming underneath me, so I inspected the driveshaft but all U-joints are solid. I also noticed that if you lift the backhoe on its outriggers and place the backhoe into drive, that the left rear wheel will rotate at a much slower rate than the right rear wheel. Any suggestions on what may cause these two issues? Any advice is greatly appreciated!
