islandspark
Hi all,
I’ve got an old Case 580B with the G188d engine that came with my property, the previous owner said it used to run so I’ve been working through getting it back to work.
I changed the oil & filters and required her and finally have her cranking but I can’t get her to run on her own (she’ll fire and run on ether)
Following other threads on the foum
I’ve checked for fuel flow to the inlet of the injection pump (good), checked the inlet screen (good) and tried to get flow through the return and injectors (no joy). Prior to screwing around any further I thought to pull the pump timing window and sadly it appears that the pump is not rotating…
Im definitely not a mechanic (an electrician) but I am mechanical. Just looking for a little
Help verifying my findings and helping understand the pump replacement process and where I can get one that isn’t at case prices!
Pump video:
Pump video:
