silverstr8p
Starts and runs fine, but then seems to starve. Was running fine after fixing clogged fuel lines and tank, but then started trying to starve the more I run it. I temporarily ran external fuel tank tied 4 feet up ROPS so plenty of gravity flow.
Replaced filters multiple times and cleaned all fuel lines. Also, removed fuel inlet to pump and didn't see any debris. What else should I be checking? I don't want to just rebuild the pump unless I can prove it's the pump. Sounds like a hard job swapping a pump (and expensive).
