DustyShackleford
Hey there everyone. Long time reader First time poster. I've recently ran into an issue that has me stumped.
I've got a mid 80s Case 680K construction King. Bought it about a year ago and it's been a good worker. I've been slowly updating things here and there to make her a nice machine.
On to the problem..... Here in Pennsylvania we finally are having a white winter which we haven't had in years. It's been in the 20's or lower for at least 2 weeks straight now. The other day I fired her up and noticed the steering was a little tight, felt like low fluid. Only took about 2-3 gallons. Typically when I've felt that on other machines before it's when they're low low. In any case, i topped her off, admittedly probably a little higher than i should have, but i topped her off. Fired her up and hydraulics were still a little tight. I let her run and walked away for maybe 5 mins MAX to let her warm up and get all the fluids warm. When I returned I had NOTHING and I mean NOTHING. No power steering, no hoe, no loader. Not even a wiggle. I've been playing with it for days now and haven't been able to sleuth it out. I have the full service manual and schematics. the 680k does have 2 pumps, One does the loader and one does the power steering and backhoe. I can't imagine the odds that both pumps would fail at once. Here's what I have tried so far.
- Verified correct fluid level, I even let out a little bit to make sure it was not over filled.
- removed hydraulic filter and put a bucket underneath then fired her up to verify flow. instant waterfall of oil. So I can confirm that at least one pump must be flowing.
- replaced filter with brand new one
- pulled what the main relief under the floor and cleaned it. Not sure what I'm looking at here or what to check for. I see the exploded diagram in my parts book, I guess I could fully disassemble it to inspect.
- I've tried it over a few days now and still do not even have a wiggle on any of the hydraulic functions. I really want to come up with a set troubleshooting path. the one in the service book for full loss just says to check the fluid level and relief valve.
I'm looking for any ideas or a set troubleshooting path to start following. I'm an electrician but I know my way around a wrench and I'm good at troubleshooting so all ideas are welcome.
