Coy Lancaster
CAL POT is for the throttle and should be calibrated first
Gary, is this for the Reverse ratio switch? the 4 position knob to the left of the joystick I am having an issue with mine I get zero ohm reading and my 850K series 2 will not move forward or reverse, and I have no display I'm heading out to check all fuses any advise on making it move or display fuse location?View attachment 182019
The potentiometer connectors should be a 3 pin deutsch if I remember correctly. Letters for the pin locations are sometimes on the connector. The wire numbers are not likely not visible. Just use a small cotter pin or paper clip to back probe the connector when checking voltages.
I don't believe your throttle potentiometer is your issue, but you may have to adjust it anyways in order to complete the calibration.
