I thought you said that the water separator bowl was only half full when you had the problem with the power loss.? Is it still the same.? It may be full when you first start up but what is it like when it becomes sluggish.?
See the link I posted above. Refer to the illustration of the fuel filter in Post #20 on Page 1.
Remove the entire fuel filter assembly from the machine, remove the element, then finally remove ALL the fuel line fittings and blank plugs from the head.
Clean each of the passasges in the filter head using either compressed air or by pushing a length of wire through it.
Then make sure all the fittings are clean by blowing through each one in turn.
Reassemble everything and see how you go.
