I have a 2012 CAT 252B3 with 2,100 hours on it and C3.4 engine. Since our temps have dropped below freezing, I've been having intermittent issues with losing power and smoking. It happened this past Monday when I went out to use it for moving snow. It was about 20*F out and it started fine (I use a block heater), idled fine for 15 minutes then even ran at high idle for 15 minutes but at higher RPM and under load it would lose power, sputter, and smoke. I'm not the best at judging smoke color but it wasn't dark black and it wasn't white. It just looked kinda blue grey. I was running straight number 2 in it then since our stations didn't have winter blend last time I filled up. But I did have hot shots secret in it and I added Lucas injector cleaner. After at least 1-1/2 hours of warm-up, it operated just fine, I got the snow clearing done, then went to town to get winter blend.
I now have winter blend in it which is 20% kerosene and I added more hot shots secret. I cleared snow Tuesday and Wednesday with no issues. A normal warmup cycle and she ran just fine. Temps were in the 20s and low 30s. Then today it was 4* this morning. I ran the block heater for 2 hours and it started right up. I let it idle for 15 minutes, then went to high idle for 15 minutes, worked the cylinders to move the hydraulic oil around and everything was fine. I let it run at high idle for another 5 minutes and it started to smoke and sputter again. Within a minute it would clear itself up and run at high idle again but a few minutes later RPM would drop and it would start sputtering again. This cycle went on for 20 minutes and finally it was running as it should. I cleared snow for 10 minutes without issue and then it started sputtering again. It sputtered off and on for 10 minutes and finally died. It had never actually died before. It started back up, smoked, sputtered, had no throttle response and died again. I put a heater on the fuel filter, plugged in the block heater so at least it wouldn't cool down and let it sit for 20 minutes. It then started and ran just fine as I drove it for 5 minutes to get it out of the way and into its parking spot where I left it.
The injector pump was at least 60*F, the block was around 150*, the fuel filter was right around 32*, and each exhaust port was about 180* when it died. I crack the water separator on the filter every day but I never get anything out of it. Some days I'll hear gurgling when I open the valve and some days I don't hear anything but I never get anything to drain. It's a new CAT fuel filter with less than 50 hours on it.
This is my second winter with the machine. Last winter was colder than normal with more snow than normal and I never had these issues. I did have to warm the fuel filter last year when temps were below zero but I don't remember ever losing power and having the sputtering. Any help is greatly appreciated. Some questions at the top of my mind are:
1. Should I run some iso-HEET in the tank and is that safe for the injectors?
2. Shouldn't I at least get diesel out of the water separator when I drain it? Or do these separators somehow keep the diesel from draining?
3. Should I be draining the separator after operating when at temp or before operating? I'm thinking after operating any water would be liquid and drain vs being frozen.
4. Any other suggestions on what I should try?
TIA
TIA
