Hi, I have a 2013 CAT 272D XHP that I am having an issue with. When I turn the key on, the following will turn on - head lights, ac/heater fan, display light one bucket leveler, windshield washer. But display monitor will not come on, also if I turn key to try and start, it will not try to start, I don't even hear any relay clicking of anything when I do that. It has a bank new battery. I have check the following. ground strap under cab, and positive and negative cables at the battery and starter. I see it have two control module apparently, one on the engine (engine control) and one under the cab (machine control). The machine control is silver and not made of plastic, does it need dissembling to look for loose solder connections? Would you please help me out with this? I have been looking online for a service/troubleshooting manual and so far all I found was a similar schematic, and operators manual.
