CAT 272D XHP No Lights or power to monitor, no crank
There are two of them that I know of, I was trying to determine the circuit, this one is on the firewall on the right side by the starter. And another one is on the firewall under the cab behind where the seat is.
You have the electrical schematic. It’s easy to identify which one is which by looking at the wire numbers/colours connected to each one.
h2y
Central Texas
You are fortunate to have the A-Team already replying to your dilemma. I notice you are a fellow Texan, home to many rats & mice. Have you thoroughly searched for poop & the accompanying chewed wires? Especially under/behind access cover plates under your cab? I resolve many of my issues by repairing chewed wires. Interestingly, recently I found skunk hair inside an open electricals door of an excavator. A week later there was a pile of dung instead, ID'd by ScatID as a bobcat's.
Here are two snips from the electrical schematic. The easy way to tell which is which is by the two small 18 SWG wires that connect to the coil in each case.
Also the fact that the main red power into one relay is 10SWG, the other one is 6 SWG. Big difference.
Jrod25
Texas
I understand , At this point, I'm just trying to get past no display no start condition and that's just one of the items I found
Jrod25
Texas
I keep finding things thinking it's going to be the fix, but not yet, lol. Thanks for everyone's help!!
So far I found and fixed -
1. a melted relay, but still functioning (replaced) , 2. the 117-9080 all rusted to where nut was partially gone, 3. bare wires on the left side taillight area 4. A nail directly shorting two wires that go to the bucket lock release. For sure nice digging thru it all so I know all the things that need addressing.
This morning I have a tech coming out with a scanner that will hopefully rule out the ecm, cmm, and point me in the right direction.
Jrod25
Texas
So the tech is saying that the display is causing the CAN to not communicate with the rest of the system and it needs to be replaced. His scanner is coming back with incomplete. "cat ecm detected on cdl data link not detected on j1939" I would think even with a dead display it would at least crank, but he is saying because of all the safety features without the display it will not allow it to crank.
I bench tested the display later that day and with pins 1 and 2., and its only draws .4 milliamps , which I think it means that the display is totally dead, I would think that with power applied there would at the very minimum be a faint backlight, but it has nothing. The part number is 378-1006.02 does anyone know if this would have to be programmed if I buy a replacement and if this is the current suggested part number 543-1326, 5431326? These are pricey so I would like to be sure. $1,100-$1,400
There doesn't seem to be any clarity one way or the other. The operating software for the Advanced Display module has had a variety of Part Numbers over the years. I see 553-1194 being replaced by 578-6309 which in turn was replaced by the latest number 608-9077. Your local Cat dealer may be able to provide more information.
If you could track down a used display then it would be guaranteed to have software loaded. Maybe not the latest Part Number, but it would certainly be plug & play as regards operation.
The 378-1006 Part Number display was replaced by 543-1326, which in turn was replaced by the latest number 657-4558.
There is also a Remanufactured Part Number of 20R8760 where your old display would be taken in part-ex for a remanufactured component.
Jrod25
Texas
Hello everyone, I'm finally able to look at this skidsteer again. Here my update. So I did purchase a new display and now it cranks, it will start only if I put one small squirt of starting fluid into the breather. Attached are the only two codes it has, currently my auto leveler (inclinameter) is missing so that is why I have that error. The fuel gauge most likely is because when I got the skidsteer the stock fuel tank was no longer used and it has an add on tank it's using. Also I am wondering if these two code are why the machine ecm shows incomplete. When I start on starting fluid everything appears to be working fine. Forward, reverse, turn, lift, lower, tilt bucket.
I have SIS on a laptop but the program is kind of difficult to navigate and find what I need, currently I would like some sort of manual for troubleshooting, I'd like to test the fuel pressure but not sure if there is a port for they and where. Is there a general overall manual for troubleshooting I can purchase that someone recommends.
Do anyone have any ideas on where I should look next or what my issue may be, it was working before as the previous owner started so I really don't think it is compression. I checked the hose out of the filter to the secondary pump is what I think it's called and it's clear, when I turn key on that line only has 10psi, not sure if that's normal, but I thought in the fuel rail it should be higher and so I'm trying g to figure out the best way to test that.
Simon C
Heavy Equipment Mechanic
Did you prove yet whether or not the glow plug heater is working through the relay. It will need to work or it will need Starting fluid otherwise. That will be a good start.
Simon C
Jrod25
Texas
Simon C
No I have not, I will look the relay, I ended up disconnecting all the connections to the filter housing and verified all the ports are clear. Also I don't think I mentioned I did measure 10psi of fuel pressure coming out of the filter housing
Jrod25
Texas
I'm not sure mine has glow plugs, I could not see any, i going to look and see if my has an air intake heater instead.
Another side question, does any one have a clue why the beeper always beeps and also what the red box symbol that is lit up is for? The yellow triangle blinks and beeps like every 2 seconds and never stops, and the red box also lights up see attachment.
Did you read the electrical schematic you were sent.? Your machine is equipped with an air intake heater, although somone has messed up the schematic by using an illustration with the icons for four glow plugs with a title of Air Inlet Heater under it..
I would suggest that you consider getting hold of an Operation Maintenance Manual at the earliest opportunity. Search for Caterpillar Publication reference SEBU9084.
To answer your questions: -
The flashing yellow alert indicator on the left is the general driver alert. It is usually an indication that something is wrong elsewhere because another indicator may also be lit at the same time. Machines equipped with aftertreatment systems generally use this indicator to show a problem with emissions equipment such as a failure of the DPF to regen.
The red alert indicator signifies that the hydraulic system lockout is engerized. I suppose your next question is going to be which is the switch that de-energizes it.? Back to my recommendation above regarding a manual.
Simon C
View attachment 354670View attachment 354671
Sorry if I used the wrong terminalogy, but yes he needs to see if what I always called a toaster oven is working or not. Good of you to have posted the correct picture or else he would of been looking for it a long time on top of the head instead of the air intake where it is located.
I always look for a large red cable and usually there is where I hang my micro clamp meter that can read up to 400 amps and fits in tight spots and tells me how much juice if any is flowing through.
Better to always have the correct terminology or sometimes we might lead some down a rabbit hole. LOL
Simon C
Simon C
The Intake Heater is powered by a large Orange #6 cable coming from the Intake Heater Relay.
The relay coil is energized by Wire F793-RP5 OR18.
If your machine is outside and cold, there should be 12 volts at this small wire when trying to start.
This relay may not work if the outside temperature is too warm. I seen a chart before that showed how they are controlled, and they are temperature controlled by the ECM to be on only as required.
They can be on for a few seconds after start up to help get engine running smoother.
If the heater is working then you will be looking at injection problems or something else.
Needs to be verified good or bad.
Simon C
Remember (as has been discussed before on other threads) that the intake heater strategy, like the one for the glow plugs, depends on the engine coolant temperature. A coolant temp sensor that is faulted or producing erroneous readings could potentially inhibit the operation of whichever start aid system the machine happens to be equipped with.
Jrod25
Texas
Thanks, the unit does have an operators manual I found, but it's difficult for me to follow. It's not like spelled out. My has a high pitch beep with the flashing amber light, but I don't thing the high pitch is the horn as it cannot be heard outside of cab with door closed
