Mathew Herman
The machine will start and run, when the RMPs are raised the machine will lose power and barely run. I hotwired it directly from the battery to the electric fuel pump and it works good. It seems that there is a problem with a ground, a break in a wire, or a blown fuse/relay.
Has anyone had this problem not receiving fuel to the pump when the key is on? Does the electric fuel pump have its own independent fuse or relay? I've only seen a fuse for the fuel shutoff.
