rev16.11invoice
CAT ET is throwing a code for "low fuel rail pressure" (~2700 hrs on loader)
I have swapped the fuel pressure relief valve with a known good one from my second unit and problem continues.
I do not see any signs of leakage/ crushed lines and fuel filters have been replaced.
The lift pump is a mechanical type and I have replaced it.
Pressure is typically 6000-8000 psi until wide open throttle (WOT) and will go as high as 17900 psi under load
Historically when the problem occurred the loader would die and at best limp off the road. This began in August and has been intermittent. It is now more or less all the time and the loader cannot do work.
Today (-20C) in gears 1-2 the loader operated fine and could maintain WOT at top speed @ ~8000 psi
However in 3-4th at WOT pressure would drop as low as 1300 psi and become erratic (2000, 3200, 5000, 7000 psi...) and the loader would bog and once again show the "low fuel rail pressure" fault.
The fuel pump has a computer controlled solenoid that will either close or open to increase pressure at the rail. The injectors do have a "leakoff" port and in theory could bypass fuel were they to fail.
I can post IATs and ECTs and any other sensor data under varying load conditions if you think this may help direct me, but I believe the senors values are correct and do not suspect the values they are providing the ECU...
