CAT 950G No output from ECM to starter relay
Brian Bobb
Saint Lucia
Can anyone help me figure this out. Power from the key switch is going into the ECM through wire 307 but no output from 306. G763 and G764 has ground but it just won't send the output to start the engine.
ahart
Indiana
Do you have ET to be able to see what the status of the parking brake and FNR switch is?
Brian Bobb
Saint Lucia
Also it would be nice if you posted a machine Serial Number, or even better the Publication Reference to the electrical schematic, so that we could look at the same thing you are.........
6JK01798 is the serial number for it. Oh I don't know the publication reference just the starting starting system and the park brake wires numbers I got from a guy.
Brian Bobb
Saint Lucia
hey id love a trip to stl ....:):):):):):):) im right next door
on a real it could be the fnr switch
You're right next door? Dominica? Saint Vincent? Trinidad? Lol. How can I go about checking the FNR switch? When I use a multimeter and check the wires from the switch, the ground connects to neutral and disconnect when you switch to either forward or reverse.
ahart
Indiana
Looking at the schematic it sounds like the switch itself is working correctly, I would check the wires from the switch connector to the ECM connector. I’ve seen a few harnesses break in the steering column and cause issues.
Brian Bobb
Saint Lucia
I checked the wires from the FNR and the keys witch, they both are sending the ground and the power when you turn the key to the start position. I checked the schematics that I got from Nige and 306 is the one that sends the output to the starter relay but nothing is coming out from that. I honestly don't know what else could be the problem. Also it is a new ECM that was installed.
Brian Bobb
Saint Lucia
Yeah, I tried jumping the black and yellow wire and the ECM still refuse to send power out the green wire marked 306. What else could possibly cause it to not want to crank?
