Shivan Dookeran
Don't know how much they gonna charge but I have my guys here I can put you onto that can and will be able to sort you out . Hey nige does the axx and 2js have the same Trans ecu?
At the end of the day they do, along with about a 1000 other models. As stated previously it's the software that's installed in a particular ECM that gives it its "identity" - and here's the rub. The newest iteration of software for a 2JS machine is 229-4976. The software for an AXX Series II machine is 255-7943 and the two don't cross reference to one another that I can see. My guess is they don't.Hey nige does the axx and 2js have the same Trans ecu?
According to you, new ecm installed. What did you do to the new ecm before installing it?Yeah, I tried jumping the black and yellow wire and the ECM still refuse to send power out the green wire marked 306. What else could possibly cause it to not want to crank?
Answer to Q1 - nothing. The new replacement ECM is apparently blank.According to you, new ecm installed. What did you do to the new ecm before installing it?
What happen to the old ecm?
Ok.Answer to Q1 - nothing. The new replacement ECM is apparently blank.
Q2: The original ECM was stolen.
