I have the roller frame laying on its side in the shop. The three 5/8" bolts are the ones located under the tractor that attach the roller frame to the loader frame. The first thing that I did was to grind the broken bolts level with the surface as shown.
Next, I drill through the bolt and out the other end. At this point I don't know what method I will use to remove the bolt but once drilled, I can not loose center of the bolt later on.
Next I drill twice more with successive bigger bits. I try an ease out that usually won't work, even with added heat. Being really careful not to break the ease out off in the hole.
Note how well the Harbor Freight drill bits cut the grade 8 bolts by the shavings they leave. The bits are not so hard that they break off in the hole. They just bend if you side load them. I have a nice set of titanium bits but the least side load and they will break off in the hole.
44 assorted bits were $7.00, what a deal!
After drilling three times, trying a ease out, trying cherry red heat, welding on a nut and washer, nothing has worked on these three 5/8 bolts. In the morning I will burn them out with oxy acetylene down to the threads, then I will use a pick to unwind the threads out of the hole and then clean up the existing threads by running a tap through them. For the best outcome in a situation of this sort it is best to do such a delicate burn out operation when you are fresh and have plenty of patients. If I fail to burn out the bolts and clean up the threads then I will drill and tap oversize to 3/4". I would rather not have to do that.
Sometimes you come out better to just cut the lights, lock the door behind you and go to the house before you screw up something and make it unfixable. Tomorrow is all mine and a new game begins, old man VS machine!
