Cat 963c two speed not working moves slow
Sbird
Missouri
It really isn't that complicated. The motors get charge pressure down one of the small lines and signal pressure down the other. The charge pressure is what moves the swash plate, the signal pressure against the spring pressure shifts the control spool and the spool directs charge pressure to either side of the swashplate piston.
Next question. Do you have charge pressure at the motors? You will need to tee a gauge into the line.
(I have a gut feeling this might be a blue-cap issue)
The only other small line I see on motors is coming in the center of the motor not on the motor control ? There are signal hoses on control and a crossover line between two motors that’s all I see for small lines
JAJ
Owner operator of small fleet
Hi guys you are all going to great lengths to get to the bottom of the drama for the OP… and OP is doing a great job of the troubleshooting at his end. It is a showcase of the forum at its finest! It’s also very fascinating reading
I have never driven or worked on a track loader, so I may be way off with this but I have just been reading through the spec brochure for this model machine to understand some more about the machine in question. I just spotted some interesting points and it leads to my question. It states that the Electronic Hydrostatic Control (EHC) automatically adjusts machine speed to give priority to the equipment hydraulic system, while the hydrostatic system uses the rest of the power available. Does both systems use the same pump and if so can the problem actually be in the hydraulic system somewhere (as it has priority) and the symptoms showing up in the hydrostatic system due to not enough flow?
Cmark
Here's the 963. It's actually even simpler. The pressure to destroke the port plates comes from the drive loop. If you can confirm that the motors are seeing signal pressure by plugging a gauge into the end of the hose, then I don't see how it can be anything other than a motor problem.
But two motors with the same fault? I don't like those odds.
JAJ
Re my above post…. It was a stupid question, I have just re read the pdf data uploaded earlier in the thread.
Seperate implement pump is shown, should have read it properly my apologies.
Two seperate pumps and motors both with same fault doesn’t seem likely unless they are just worn out from natural causes, is this a possibility?
What is the rpm drop limit that the ecm starts reducing travel speed? Could someone have played with parameters like this via ET?
Cmark, I remember when I spoke to you about getting ET some time ago that you warned me (very rightfully so!!!) that someone can cause a lot of problems to a machine with “Dealer Level ET” if they don’t know what they are doing. If you get my drift, thinking about the old owner replacing the ecm himself. Just a thought
Sbird
Missouri
That’s what I thought I will put a gauge on signal hoses right at motor and confirm the reading the computer shows is accurate I keep reading that motors won’t destroke until the pumps fully stroke so I’m guessing that if signal pressure is good then that has to mean pumps are fully stroked right ? Or am I missing something ?
Sbird
Missouri
Yes Jaj this forum is the best I can’t say enough good things about the experts on here I owe them all big time and really appreciate their willingness to help and provide valuable information this forum has been priceless to me
pittsburgh cat man
saltsburg pa
Don't get discouraged from what you have said there has been a lot of part changing trying to fix the problem. As far as pumps being at max stroke I would say that it is a real good chance they are. We just need to study and think awhile ,We'll get it figured out
Sbird
Missouri
Ok had short hose made with fittings for gage and unhooked signal lines from motors and installed gauges on signal lines getting 300lbs pressure around 2000 kpa on both lines when full forward high idle so pressure is for sure reaching motor control just need know why they aren’t destroking when there is sufficient pressure to them to do so
Sbird
Missouri
The adjustment screws for rate of stroking are almost all way in is it possible that if they are screwed too far in it won’t destroke or I adjusted them out like two turns or three when we attempted to set them but is it possible that I might need back them off more or is even possible to tighten them to the point it won’t destroke? I was afraid of backing them out too far didn’t know if that was possible
Cmark
This is a cross section of the motor controller from SIS. The signal pressure is in brown at the top. As you can see, it is dead headed at the controller and only moves the servo spool.
You can safely remove the end of the controller to inspect the internal components. You will lose a bit of oil though.
Cmark
If we refer back to the graph (which is actually more than technical gobbledegook) we can see that both pump and motor see the same signal pressure. The pump is designed to upstroke from 30 - 115psi, at which point you will be moving at approx 3.5kMh. The fact you can get to about this speed with the signal line to the motor blocked means the pumps seem to be working OK.
From 115 - 217 psi, the motors take over by destroking.
To say that the
is kind of missing the point. It's not the case that the pumps somehow control the motors and the motors aren't allowed to destroke until the pumps are fully upstroked. It's just the way the system is designed, with the motors taking over at the pressure the pumps finish upstroking.
Sbird
Missouri
To say that the
Ok got ya I thought that was what it meant but wanted make sure I wasn’t missing something there
pittsburgh cat man
saltsburg pa
On opposite end of motor controller from the stroking adjustment there is a plug where you can put a tap for de stroke oil pressure. since we have signal pressure might be worth checking
Sbird
Missouri
I seen that in book was wondering same thing what is pressure there saposed to be ?
Sbird
Missouri
Was reading in stuff nige sent about drive motors and seen it says pressure adjustment screw limits max speed and minimum angle stop screw also limits top speed I understand the minimum angle stop screw but I see nothing in the picture above it that shows pressure screw any idea what book is talking about am I missing something
