fmatemberere
I removed a transmission from 988H to change the mounts. I fitted back the transmission and all the oil lines.
I topped up the transmission oil using the quick fill but it took a while to show on the side glass to the full mark. I walked away to do something else but when I came back the oil level had dropped down but before the machine is started. I topped the oil again to the full mark.
I started the machine with someone on the ground checking the oil level .The oil level rose up to the overfull position instead of going down after just running the machine for less than a minute.I stopped the engine and removed the transmission oil filler cap but pressurized oil shot out of the transmission.
The oil level on the side glass dropped down to low but oil kept coming out of the oil filler tube.
I need your help please. I am thinking I might have overfilled oil in the transmission but why was it not showing on the side glass or maybe I might have interchanged oil lines.
Please help.
Please help.
