Hello everyone! I bought a D4C LGP and I’m having issues with the blade . When I use the blade lever in full motion sometimes the blade will function very slowly . When it does that I bring the lever back to neutral position and then I go half way and the blade operates quick as it should . This happens with all functions of the blade except when putting the blade down . And this issue does not happen every single time .
I also put the blade down and it lifts the machine all the way up . I checked the linkage and everything is tight and connected properly. Any help will be great appreciated. Thanks
