Slim Tech
Car D5C left tankt is stuck in reverse. I capped off line F on the pilot joystick to make sure it wasn't just bypassing inside the valve. Removed the top cover on the front pump, according to sis this is where the actuator is, actuator was stuck in what would be the reverse position, encouraged it back down with a 3lb hammer, ball peen wouldn't budge it. Blew air through line F and made sure it would move up and down. Reassembled and still doing the same thing, left track stuck in reverse, right track moves propero with the joystick.
Replaced hydraulic filters and cut them open, SMALL amount of brass, not much at all, looked like normal wear, nothing like a pump/motor failure by any means. Any other thoughts? I've not run into this before, I have SIS abd looked through the schematic, it all seems to point to the actuator, do I need to go ahead and take it out? Several things need to be removed is why I haven't pulled it yet.
Tia!
Tia!
