sbsimkins1
I recently bought a Cat D6C 76A5186 with a fuel problem. There was a small electric fuel pump hooked up to it and it started and ran so I bought it thinking I would just fix it up. It turns out the fuel pump was rusted solid and it broke a gear tooth on the pump and bent the rod. It also broke a gear tooth on the accessory shaft. I believe I have found all the parts to fix the pump but I can't find an accessory shaft. The parts book calls it a 1S7401. If anyone knows somewhere to source one of these or an alternative fuel pump I would really appreciate it.
