And sometimes that weep hole can get plugged by insects and a leaking water seal on the pump will force coolant past oil seal. Never understood why they did not position those weep holes so you could view them easy and keep them clean!Pull the engine oil drain plug momentarily and look for coolant in the basement.
Sometimes the weep hole on the water pump leaks and the koolaid evaporates before it’s able to be detected.
Just a couple quick checks.
Cause engineers never think we have to actually repair things they design.And sometimes that weep hole can get plugged by insects and a leaking water seal on the pump will force coolant past oil seal. Never understood why they did not position those weep holes so you could view them easy and keep them clean!
I’ll try this, I believe there is a large screw on cap that has a rubber tight seal and then there is a standard looking radiator cap that would relieve pressure if there was any.are you building pressure in the radiator is coolant blowing out the over flow. crank up the dozer let it run a minute remove radiator cap is there any pressure. check your breather and dip stick any sign of moisture
